Engine hose / piping supplier needed
Does anyone know where I can get hose pipe. They are vacuum pipes, so shouldn’t collapse, and sit near the engine so should be heat resistant. They are about the diameter of a pencil, and are from my Idle Air Control Valve - they go from it to the 3 throttle bodies. I need around a foot of it.
I’m having problems uploading photos - so if you think you can help, I can email them to you.
Any suppliers of this sort of stuff - London area if possible.
cheers
:slight_smile:
samco?
I would think most decent hose would be ok - it’s not a high vacuum application, so unless it’s particularly thin-walled shouldn’t collapse.
Try rs components
http://uk.rs-online.com/web/
They have trade counters (Iknow there’s one Heathrow . Staines area)
Or try a Parkerstore (don’t know of any in London, but I know MF hydraulics in Reading)
http://www.parker.com/portal/site/PARKER/menuitem.7100150cebe5bbc2d6806710237ad1ca/?vgnextoid=f5c9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=default&vgnextdiv=&vgnextcatid=6122663&vgnextcat=INDUSTRIAL+HOSE+-+EUROPE&Wtky=HOSE
