Right, my SV (04) engine has stated to cut out while riding it. It’s normally in low gears and low reves. It an injection version of the SV and it’s due it’s major service of 30,000 (although I have given it an oil and filter change this year).
What is causing the Engine to cut out?
Could it be the injection or idle timing of the bike? Or something else all together?:w00t:
Sounds like it could be one of the engine management sensors playing up…the lambda sensor would be the most likely culprit, presuming you have one of these fitted on an SV. The diagnostic computer at the garage should be able to identify the problem straight away when you take it in for its service.
