Electrical questions...
I have no idea about what i think are called “wiring looms”. Nowt, nuffin. I am a n00b.
Can i wire in something to give me a cigar lighter socket on the bike for charging my pda/phone/lighting cigars?
And what about stuff like heated gloves? how to they draw their power? what do i need to add to the bike for the upcoming winter mornings? Are heated grips better? how do they tap into the bikes electrics?
What about rider-pillion communications?
I know nothing about this and google isnt helping atm… I’ll continue searching.
Advice sought and kindly given,
R
just get a car.
take two flexible wires…with at least with 10 strands of copper inside them, one red one black…run the black wire from your battery negative to the negative of the newly purchased cigarette lighter socket…take the red wire from the positive of the battery terminal into a fuse holder then onto the positive of the cigarrette lighter socket…and bobs your unkle you have an independant power supply from your bike… just fit the unti somewhere accesible and away from water…
What will we call cigarette lighter sockets when we dont have cigarettes any more…auxiliary power supply point…boring…
Oh you may ned to buy some wire end terminal connectors…bet they would be in a kit if you needed them …
I’d still get a car though…
You can get Powerlet sockets off these people.
http://www.blue-job.co.uk/main.php?group=powerlet%20socket%20kits
ok lamans turms because i wired up a souinds system and neons and lighters and chargers to my scooter lol its EASY
2 colour wires red and black makes it easyier get your lighter sockit from maplins or somewhere cut off the current connection on the lighter sockit so your left with two wires
red to postive black to negative on your battery wire them up to the two wires on the lighter socket tu da!!! done
go that extra mile cut the postive wire somwhere and add a switch :smiley:
just be cafeful not to do what i did and fuse everything and melt your hand trying to diconect it that hurt
From the start…
  1. Disconnect battery negative lead. This will be the black one :wink:
  2. Disconnect battery positive lead. G’wan, guess which colour this will be?
  3. Wire up the power socket as per the instructions for which wire connects where. You’ll also need an inline fuse holder (with fuse!) of about 15 Amps, this goes in the red wire.
  4. Connect up the other end of the fuseholder to the positive terminal on the battery with the big wire that you took off there, tighten it all down nicely.
  5. Connect up the black lead from the power socket to the negative terminal on the battery with the big wire you took off there.
  6. Plug something in :slight_smile:
It’s very important to disconnect the battery negative lead first, and reconnect it last. Otherwise when you’ve got the spanner on the terminals and the other end touches the frame you’ll get a shock and a big spark. The battery is usually pretty close to the fuel tank… :w00t:
You sure you are in the right forum Birdy?;):stuck_out_tongue:
Well thank you LBers, as ever I was overcomplicating matters in my mind. Just strap the thing acroos the battery, stick a fuse in and bobs your fathers brother.
:slight_smile:
R
Better if you can find the ignition feed from the main fuse box & wire the +ve to a spare connector there to avoid you draining the battery when not switched on. That’s even more important for the heated grips.
easya cigarette socket will cost you 50p from maplin, a relay you get for £1 from a breaker or a friend.
job done.
http://www.cartestsoftware.com/fz1/cigarettelightersocketinstallation.html
:open_mouth: you cheeky sod im a scooter pimp master mind when it comes to electrical gadgets iv just wired up a cd mixing deck into the seat of my mates scooter and we have fit speakers in every pannel LOL
WHY?:w00t:
Is it fused ?
or Con-Fused;):smiley:
yea it works perfectly and why BECAUSE I CAN :stuck_out_tongue:
http://www.youtube.com/watch?v=YDjcM7J_f6A thats m=rite thats my old beast :smiley: 56 plate
http://www.nippynormans.com/prodinfo.asp?number=BAS-ZA01&variation=&aitem=2&mitem=4
