The DRZ has seen some pretty hard abuse over the winter, being my every-day hack to use in the conditions I wouldn’t want to use the Gixxer in, so it’s had a hard time, compounded by the fact I’ve learnt to stunt on it. So the time has come for me to give her some tender-loving-care. Tasha and I set about stripping her, replacing worn components and starting a cleaning process.
Once the plastics and tank were off, we could see what needed doing, and this is how it stands:
- Replace the clutch cable (wheelies have killed it)
- Replace front brake hose with a braided line (first step towards supermoto)
- Replace spark plug
- Replace air-filter
- Replace oil & oil-filter
- Install new rear indicators (for mot)
- Fix tail-light (for mot)
- Thorough clean of all components
- Repaint side-stand black
- Fit smaller Renthal front sprocket & engine-guard
- Buff the hand-guards
I’ll also fit some new bits to it over the end of the summer, bringing it towards supermoto form, i.e. new Renthal bars, new plastics, sm wheels, bigger front disc, caliper adapter and new chain & sprockets.
Man, I love this bike so much, it’s been wonderful to me, never let me down and proven to be ultra-fun through town, especially in the wet when powersliding around the streets.
Here are some snaps of us starting the work. At the end of the weekend she’s had the clutch line changed, indicators fixed, tail light half fixed and all components thoroughally cleaned. The braided hose that I’ve had laying around for months caused a lot of hassle though, it turns out it has a leak near the banjo bolt, and I only found this out after an hour of ****ing about wondering why I couldn’t draw any fluid through, so blasted some fluid up from the caliper using a syringe, only to have it splurt out all over me… argh…
As you can see, we made good use of the new enclosure I’ve had built this month for my bikes. It’s taken a BIG weight off my mind, as I no longer have to worry about my **** of a neighbour and his jealousy towards my bikes. Security has been increased as well, with a water-hose in place for the jet-wash. Motion-activated flood light to come.
