not the best of weeks. bike lost power at brands and by the time i was back in the pits, the engine was a gonner
have to say i’m not overly happy with the second big issue in a year. last year it was the genny chewing itself to bits, this time the valve decided a game of pinball was in order. costly, and highly irritating/inconvenient
bike is being stripped down to see the extent of the damage but am told that at the very least the valve in question, the piston, and the cylinder head are all likely to have got involved in the party so will have to get on the hunt for parts again, assuming there is enough of the engine to salvage.
bit unsure what is best next step. is it likely that even with a rebuild that the engine will be good again? do i need to find a new engine? is the bike even worth keeping after i’ve done all this or am i best to get it running, get shot and buy something else?
have to say i’m pretty uninspired by the recent crop of sportsbikes out there. they all seem to have been penned by a cross-eyed work experience student. well that is apart from the ducati, which is eyewatering to buy newish spec, not to mention running costs.
Malcolm at Yorkshire Engines always has a selection of good engines available, has a great reputation and each engine comes with a warranty. Can often be cheaper to just slot in a second hand unit and sell yours on eBay than try to fix a damaged engine.
(His web host appears to have a problem right now)
Really sorry to hear this Ben, that sucks mate! There must be good engines about at breakers, how many bikes are written off because the forks are bent and the swingarm has a scratch on it…
just had a word with the guy at yorkshire engines, very knowledgeable guy. thanks steve
unfortunately he doesn’t have engines for it in stock but well worth the call. from the sounds of things spare engines are a bit thin on the ground at the moment
apparently my genny chomping itself is actually pretty common on the 04-06 bikes so at least i’m not alone in that repair from last year. apparently its worth taking a look at every time you drop the oil. who knew eh?
given the fact that i wasn’t bouncing it off the limiter or being overly aggressive with the downshifting, it appears i’ve just been unlucky with the valve. i’m not sure if that’s comforting or not
