Datatool system 3....any engineers here?
When i started my bike this morning the idle was 4000 rpm.(aprilia rsvr 2004)…after forum searching on the Aprilia site i was told it could be alarm related
I was told to try…press the round button of the key fob (just to switch alarm off) - turn on the ignition - press and hold the round button until you hear a beep and release button - press and hold the round button until you hear a beep and release button - press and hold the round button until you hear a beep and release button - turn the ignition off and back on and start the bike
Wow…it worked, now runs fine like before
was then told…There is a known issue with Datatool alarms having one of the immobilisation circuits connected wrongly in the loom - guess yours is one of the affected ones.
Mine was wired wrongly too
I will be booking my bike in to an aprilia dealer…(Southern Cross) to see if they can sort it but just wondered…What did the sequence do…??? Any ideas
Cheers peeps…And hello i’m newish…:stuck_out_tongue:
Send a PM to CharlyBR600-RR and also read this
http://londonbikers.com/forums/Topic156455-65-1.aspx
Have done both cheers mate
On another forum i’ve been told it resets the datatool system…:)…it worked thats the main thing
