There’s a chain of stores called HobbyCraft (Or HobbyKraft, I forget…) that sell the exact stuff you’re after by the metre. I’ve used it on my car and it works well - even resisted spraypaint! The stores 'emselves are few and far between, though!
this all sounds like a nightmare waiting to happen! Just get a decent match paint, sand it down, get the right primer, paint it, rub it down with some 1500 grit and laquer it, simple as. Seriously take your time and dont rush each stage and you’ll have a pro finnish rather than a stickback nightmare full of creases and bubbles
Thanks for the suggestions guys. Some more suitable then others
What I’ve decided to do is I’m going to buy a set of those white go faster stripes you see on Novas and Fiestas, cut out the shape that I need from one of the strips (I only need a small amount), then to finish it off get some nice small red Aprilia stickers and stick them in the bottom corner. Should look sweet
Then the leftover white stripe, well, I could just put it on my cage, adds at least 10mph
