Computer problem
My laptop has started behaving oddly…The task bar disappears from the screen and I can do nothing other than hit the off button. When I do this a message about an unresponding program appears.:angry:
I have no idea what the program is or where it is but think it’s the source of the problem.
Program shows as BrMfcWND.EXE
Anybody got any ideas on this?
Cheers
well that process is the brother status monitor… for your printer.
It sounds like its crashing explorer. I assume your not using Vista? otherwise explorer would reload itself
Did you recently install the drivers for your printer? If so, you might want to uninstall the status monitor.
it’s either a problem with your printer software, if you have a ‘Brother’ printer, or malware.
shando
Not using Vista . Brother printer has been installed for 6 months or more. What would cause it to start behaving like this?
Cheers
had this with a work PC the other day it is a Virus, I had to do a rebuild on it as I could not get it off…
So, not good news then?? It is running slow and when I have multiple windows open I can’t pull them back up.
Recently changed from Kaspersky to Avast - maybe it was a bad move,
Thanks
my first guess would be that BrMfcWND.EXE is actually not the culprit. If you could identify the real culprit, it would be easier to remove. Run a full scan and see what avast identifies
if you need any help give me a shout I leave in southeast london… maybe able to see what I can do for you…
but sounds alot like what I had and I was pretty much screwed as there was no way of getting the task bar up. and boy was it slow…
Even the virus scanned did not clean it…
How to remove BrMfcWnd error
The free file information forum can help you find out if BrMfcWnd.exe is a virus, trojan, spyware, adware which you can remove, or a file belonging to a Windows system or an application you can trust.
BrMfcWnd.exe file information
The process Status Monitor (Main) or Brother Status Monitor MFC Application belongs to the software Status Monitor or Brother Status Monitor Application by Brother Industries, Ltd (www.brother.com).
Description: BrMfcWnd.exe is located in a subfolder of “C:\Program Files”. Known file sizes on Windows XP are 819200 bytes (68% of all occurrence), 622592 bytes, 815104 bytes, 802816 bytes.
There is an icon for this program on the taskbar next to the clock.
File BrMfcWnd.exe is not a Windows system file. BrMfcWnd.exe is able to record inputs. Therefore the technical security rating is 25% dangerous.
External information from Paul Collins:
“Status Monitor” is not required to run at start up.
Important: Some malware camouflage themselves as BrMfcWnd.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the BrMfcWnd.exe process on your pc whether it is pest.
We recommend Security Task Manager for verifying your computer’s security. It is one of the Top Download Picks of 2005 of The Washington Post and PC World.
Avast is good. My other half Dave uses it all the time so added it to my computer as I was using AVG, also good, by not free.
Its always worth doing scans on a regular basis including disk cleanups and defrags.
Good luck with it, hopefully you’ll get it sorted soon m8.
Just run a full scan and it found 7 problems - cleaned them and all seems back to normal.
Thanks to everybody for the input:)
There’s a free version of AVG too which seems to be OK.
Hopefully it’s sorted, make sure you rescan after a full shutdown/power off and restart, as some of these little buggas are very persistent and reproduce more than a good catholic mother !
Yeah I used to use that but got fed up of renewing it every 30 days so paid for it in the end. :smiley:
Spoke too soon - it’s doing it again…:angry: I guess I’ll have to take it in to somebody to sort out.
The proper free version doesn’t need re-registering or owt, just install it and leave it updating daily !
Nightmare… where are you based ?
Go to F-Secures website, they have an online scanner, give that a whirl
[quote]
marklid (29/08/2008)
Nightmare… where are you based ?[/quote]
I’m based in Budapest but in Spain at the moment - only been here for 2 weeks so my Spanish is not up to explaining the problem to any repair guys here:)
Errrrm was gonna say if you can get to East London then I’ll have a look… but Spain (and indeed Budapest) are a bit far…
If it’s a virus you can either
  • reformat your computer and start again (after backing up your documents) BEAR IN MIND I DON’T KNOW IF ANY DRM (i.e. PURCHASED MUSIC WILL WORK AFTER A FRESH INSTALL - MAYBE SOMEONE CAN ADVISE)
    Or if you wanna get involved you can build a Windows boot disc and use antivirus and HijackThis to try and spot the gremlins… either way it’s hassle I’m afraid…
