Hi folks,
As per my first post in the “newbie” section, I have an MV Brutale 910 and I would like to get a CO Sync and body throttle adjustment because the bike sometimes is “funny” - I.e. It goes off.
Can you recommend anyone in the London area for this type of activity?
Cheers
I must admit I haven’t thought much about throttle balancing
since I sold my last carb’d bike, occasionally I check the 2
cables on the SV to make sure both throttles shut at the same
time but that’s it, I haven’t even looked at the R6 throttles.
I assumed normal services combined with modern ECU and fuel
injection took care of things.
Exactly what do you mean by “funny” and what do you think
you need?
Hey Mike,
Basically I have some cutting problem, even when the engine’s temp is good. Normally it happens when I’m in neutral at a traffic light or at a very slow speed.
Can it simply be that the idle is too low? Have you spoken to Scorch?
Anyway I heard Rosso Corse in east London have the tools to read your emissions but I’m not sure they can flash your ECU, in case you need to.
It always happens at high temps and usually in town , once on the open road it is fine , KTM prone to this also , TPS usually to blame .
