clear tubing for brembo M/C
I have just fitted my braided lines and Brembo brake master cylinder,
The tubing that is already on my remote resivoir feeding the brembo unit seems to be too large a diamiter for the nipple on the brembo unit, where do i get the corect tubing from please? clear stuff would be nice also will i need a new resivoir?
Neil, you can use the standard hose, as I do, but you need to replace the clips with tighter ones. I would speak to Crescent Suzuki for these. This way is the easiest as you can use the stock reservoir with the stock clipons.
If you want the clear tubing, you can either get it from yoyodynti.com, or get tinted hosing from Crescent Suzuki. Crescent will charge you about a tenner including shipping, costly, but you need the right hosing, as if you get just any rubber hosing, it won’t do as the brake fluid will ‘sweat’ through and dissapate. You need stuff designed to work with brake fluid, which is a nasty fluid.
Hope that helps mate.
Cheers Jay, i’ll get some smaller clips on the original tubing.
WANT ONE ON THE 675 !!
Ta Neil.
Andrew, your bike doesn’t need one, it weighs sod all, and has a very good 14mm nissin radial unit on there already!
Hehe I know but you’ve all got one…
Go for it Andrew, just the name Brembo makes it cool,
with xtra stopping power to boot mate, you could be a stoppie king! hehehe
What else are you thinking of doing to the bike mate?
