Right well after hearing the bad news today that my chain needs replacing I’ve started looking around as to what to buy… The first thing I realised is that I’m clueless about chains and need the wisdom of other LB members to guide my purchase
I’ve been trying to answer the most basic of questions -X-ring Vs. O-ring. Just when I thought I had the answer that X ring was better I found other websites that said the opposite… What’s the truth here folks?
Also in terms of manufacturers who are the ‘good’ ones to get a good quality chain? I was recommended this one on the GSR forum but I’d like to get some further opinions
Not that I’m suggesting you do the same but my approach, having heard horror stories of chains snapping at motorway speeds, was to get the best chain I could find (DID ZVM2), new sprockets, and a Scottoiler eSystem to keep it all nice and moist. A bit of a learning curve with the eSystem but all works nicely now
True…I have started using EK X-ring chains on my bikes…Found them good. DID,RK,EK,RENTHAL,IRIS all good chainsMate Z-Ring X-Ring O-Ring theres to many rings lolAll you need is an O-RING. Will last just as long as an X-RING
DID is a quality chain - also fit new sprockets with a new chain.
Haynes manuals often carry service limit data for the chain on a specific bike - e.g. replace the chain when the distance between a certain number of links exceeds a specified measurement.
On the Hornet Honda helpfully provides a mark above the adjusters which tells you when the chain has stretched beyond it’s service limit.
You will get more miles out of your chain if you keep it clean, adjusted and regularly lubed.
I reckon I’m gonna go for Contender 2 as I don’t rag the tits off my bike (well not too much)… I know you’re supposed to go for the best as it will last longer and pay off in the long term but I’m not sure I can afford it at the moment…
Out of curiosity, which brand do the manufacturers use? They can’t make their own surely. I ride a Suzuki 650 and its lasting well so much so I’d buy another as a replacement.
Go for the best available if you can afford it, it really is worth the extra money. I had a chain snap on my Hornet (mid range chain if I remember rightly), wasn’t even that old and looked in pretty good nick but it tore the water pump and mountings off the engine.
Couple of years ago I bought the DID gold Xring (I think) fitted to the bike in my avatar, did a 3500 mile trip round Europe, including a dozen laps of the ring and a track day at Mugello and when I got home it still didn’t need adjusting, just a spray of lube each night.
