It just stopped turning on.
I turn it off for five minutes and then won’t be able to start it again.
I can’t hear the injector.
The indicator of the upper beam is constantly on (not depending on the position of its switch) but the dash board itself doesn’t work.
The starter works.
I have checked the safety device.
May be anyone knows what it can be…
Thank you!
fuses, kill switch… get a multi on the battery to check voltage, should a couple of volts over 12.
is it the one with ABS? they’re well known for cooking batteries in no time
