I’ve adjusted the regular idle screw on the bike but how does one adjust the idle on the chock. The max revs that I get is about 500rpm so the bike still stalls a bit. If fact, once it runs for a couple minutes and I close the choke, the bikes revs rise to normal.
Other than that, it’s peachy
Indeed. I would normally adjust the choke revs by the lever on the bars but that doesn’t work well. I pull the lever from off to halfway and that’s “ok”. If I open the choke to full, the bike slowly drops revs and dies.
Choke open idle is around 500revs. (Poor)
Choke closed but cold bike is around 1000revs (ok. Not ideal but doesn’t stall ever)
Bike warmed up fully is 1200-1300 revs as per the Haynes manual (good)
I have serviced the bike with new plugs, oil, filter, airfilter, coolant. This hasn’t changed the running.
I’m assuming choke cable adjustment or carb clean?
Haven’t checked yet. Never worked on a carb bike before. I’ve got the manual so I’ll have a butchers when I get a chance in a few weeks
Too busy to play with bikes at the mo. Such a shame :’(
