Can i use a 4.5Ah instead of a 5Ah Battery for CBR?
As the summers are coming I was hoping to take the CBR out for a ride.
But seems the battery is flat and has been going since winter… I can’t leave it for 1 week and I need to recharge the battery.
I’ve seen a battery on eBay and but its 4.5Ah and I looking for some advice on weather a 4.5Ah would work when a CBR 125 requires a 5Ah?
Thanks
125s struggle to keep batteries charged so always go for a higher rated battery - I would not go for a lower rated one.
Agreed. Also it may be a small engine but in cold weather it may need the extra ooophm that the higher capacity battery can supply.
Amphour only describe one characteristic of a battery, there is also the short discharge amperage ie 50amps. Always go for the same or greater specifications when dealing with batteries.
it will be fine…
