Did you buy the whole kit for the innov? I don’t need the LCD playback just need the ability to upload to a computer in case of a crash, I assume the SD card is in the camera, but then do you need two?
Did you buy the whole kit for the innov? I don't need the LCD playback just need the ability to upload to a computer in case of a crash, I assume the SD card is in the camera, but then do you need two? Curtisyou need the main box which is also the controller the cameras are just optical
I brought the whole package
Ahhhh ok, did you just hook up to battery or put the wiring into the harness/switched live?
also consider one of theses http://www.innovv.com/innovv-power-hub1-cjxt
they didn’t do them when I brought mine
I have mine wired up to a AUX fuze box from nippy Normans cost around £75
you can just get a fused live from the bikes loom if you want the system draws very little current
I have a few Aux powered bits (heated grips, jacket,lights,fone charger, cam system & cooling fan over ride) on my bike so wanted an Aux fuse box to run them all through
