I would like a c90 only column
To discuss how to improve your Honda and make it faster
Pin
Fuck off…is the usual reaction
Ok I will start this off
I have a red one which I think is faster that the gray because it’s got a bigger carb
Pin
Carb, cams, air intake, exhaust.
Great place to start!
Do you think the top box make to much drag
Pin
We it depends if you take it off…
Then… No.
A large traffic cone plastic welded to the front to act as a nose cone would improve aero dynamics
I think you might have something there
Where can I buy one from
Pin
Just steal one from a parking restriction zone…
I could not do that it would be stealing and that’s breaking the law
Pin
Ok source one in a local canal take it home and wash it in the bath for extra bling factor when fitted
Just drilled a load of holes in the leg shields I’m hoping it will cut through the air a bit better
Pin
Plus lighten the bike like they did back in the fifftys with hotrods…I totally think you are developing a real speed machine capable of entering the salt flats land speed records…
Don’t know if this next mod will work but
Just found a 75mm silicone tube which if I take the air box off I can fit this to the carb and point the open end front with a bit of luck I might get a ram air induction effect ,
I’m going to have to up the jets I’ve been told does anyone know where the jets are
Pin
NY jets are good but the Jetsons sre better…
If I change the jet do I have to run it on aviation fuel
Pin
Cooking oil from a chip shop…its free snd smells like my favourite dinner😆
I’m guessing that beef stew then
Pin
