cant fault em really yes i too had the clutch prob just splipped a heavy duty diaphram spring in was ok, i dint like the clutch was too sensitive too at the lever so i ground a bit off the bit that pushes resevoir from lever, gave it a little play.
looked after they will go for yrs
i prefer 1s that have not been tampered with so at least you know where you are settings etc.
anymore advice you need/want hop over to oldskoolsuzuki.info
I had a 99 Bandit 1200 and could get 45mpg when taking it easy. The engine is derived from the old school GSXR1100 with different cams for more mid range so it’s more usable on the road.
The end result is a torque laden fun bike which will wheelie with ease and make good progress at low revs.
Heavy on consumables like chain and sprockets and rear tyres but ultra reliable and will easily pass 100,000 miles with some basic maintenance.
On the other hand, I owned a tidy B12 for a year. Didn’t get on with it at all. The handling is old skool. You have to grab it by the balls and muscle it in the vague direction you want it to go. Nice motor and great gearbox though. I just found it a bit dull. Which is odd as it made waaay more power than the bike it replaced. Even the accidental wheelies were a bit tedious.
The finish is appaling too. I know it’s ‘budget’, but still. I cleaned mine regularly and it still fell apart before my eyes. Sold it before it turned into a lump of alka zeltser.
