This is a bricklayer’s accident report, which was printed in the newsletter of the American Insurance Journal.
Had this guy died, he’d have received a Darwin Award for sure…
Dear Sir
I am writing in response to your request for additional information in Block 3 of the accident report form. I put “poor planning” as the cause of my accident. You asked for a fuller explanation and I trust the following details will be sufficient.
I was alone on the roof of a new six-story building. When I completed my work, I found that I had some bricks left over which, when weighed later, were found be slightly more than 500 lb…
Rather than carry the bricks down by hand, I decided to lower them in barrel by using a pulley, which was attached to the side of the building on the sixth floor. Securing the rope at ground level, I went up to the roof, swung the barrel out and loaded the bricks into it. Then I went down and untied the rope, holding it tightly to ensure a slow descent of the bricks.
You will note in Block 11 of the accident report form, that I weigh 135 lb…
Due to my surprise at being jerked off the ground so suddenly, I lost
my presence of mind and forgot to let go of the rope. Needless to say, I proceeded at a rapid rate up the side of the building.
In the vicinity of the third floor, I met the barrel, which was now proceeding downward at an equally impressive speed. This explains the fractured skull, minor abrasions and the broken collarbone, as listed
in section 3 of the accident report form.
Slowed down slightly, I continued my rapid ascent, not stopping until the fingers on my right hand were two knuckles deep into the pulley.
Fortunately by this time I had regained my presence of mind and was able to hold tightly to the rope, in spite of beginning to experience a great deal of pain.
At approximately the same time, however, the barrel of bricks hit the ground and the bottom fell out of the barrel.
Now devoid of the weight of the bricks, that barrel weighed approxima 50 lbs. I refer you again to my weight.
As you can imagine, I began a rapid descent, down the side of the building.
In the vicinity of the third floor, I met the barrel coming up. This accounts for the two fractured ankles, broken tooth and several lacerations of my legs and lower body.
Here my luck began to change slightly. The encounter with the barrel seemed to slow me enough to lessen my injuries when I fell into the pile of bricks and fortunately, only three vertebrae were cracked.
I am sorry to report, however, as I lay there on the pile of bricks,
in pain, unable to move, I again lost my composure and presence of mind
and let go of the rope and I lay there watching the empty barrel beginning its journey back down onto me. This explains the two broken legs.
I hope this answers your questions.
