Braking into corners
who’s sydney? :wink:
and I hope you didnt pick anything else up!! :smiley: :w00t:
LOL classic. You lost me after ‘vocab’. Not to worry, I’ve over simplified it. There is a great deal more to it but I’m not going into one. What you should remember is I am trying to steer away from bad habits and give advise about staying in one piece. You know, slow in fast out. That kind of thing. Not trial breaking into the apex as the gyroscopic forces of the wheels are going to try to stand your bike up… but nevermind. Lets agree to disagree.
I heard that shorter wheelbase turns faster, longer is for better corner stability. Could be wrong though, wouldn’t like to call Seb a liar :w00t:
his girl does make him like that (posh that is)
Andrew&7 wrote a great article here on LB about this very thing.
Everything you need to know about cornering.
http://londonbikers.com/articles/3691/corners-a-gift-from-god-or-the-work-of-the-devil
like they said… anyway i use my brakes in corners sometimes
braking into corners is a difficult one…
if i make a mistake in a corner, or come in a bit hot i trail the back a tiny amount,more often than not tho just lean as much as i can and countersteer…
i USED to panic…and sit the bike up and brake. normally i ended up running off into field or summit!:w00t::w00t:
now i can do KD very confidenlty…leaning the bike over has no fears for me, so if i come in too hot i lean lean lean lean…and stay off the brakes!! i also use my engine braking (v-twin) to slow me, litlle dab on teh front brake and turn in to the corner…dont hold the brake into the corner…its not good!!
BUT in a serious situation i know its more then possible for me to sit the bike up brake and bring it to a stop safely, i have done it quite a few times…:wink:
my SV’s brakes are fiarly soft, i can turn the biek while using the front, but i have to be carefull as it makes the biek drift a bit…
its a hard call, 9/10 times tho you dont wanna be using the front brake while IN a corner and you dont wanna be braking to far into a corner.
i still believe in the thought of…‘slow in…fast out’
lol are you on smack? All i said was on the power (forks are extended) thus longer wheelbase, on the front brakes (forks are compressed)thus shorter wheelbase so you turn faster on the brakes…
now please go talk utter rubbish to someone that might listen without telling you to go away.
OK got it, so you like to brake into corners.
That is what Seb said…so you agreed with him…now everyone hold hands and say ‘thank you’ to your neighbour… :wink:
