OKay … just bought myself a “brake light pro” for the ZX10. Wiring looks simple - connections to TWO wires … but then I looked at the ZX10’s wiring diagram and the input into the LED. THREE wires (!!!)
Below is the Brake Light Pro install diagram, and the other, an extract from the ZX10r Wiring Diagram.
that would be helpful - but i’m guessing the middle connector on the diagram is the earth (the black one, given the two other are have red on them) and its common to all the lights, which looks like a common earth to me.
According to the wiring diagram the BL/R (black/red) wire connects to the brake light switch therefore this will be the brake light live. The R (red) wire also connects to the license plate therefore this will be the tail light live. The BL/Y (black/yellow) wire connects to all the lights therefore this will be the earth but you don’t need to worry about that, don’t splice into the earth wire its easier to simply connect the brake light pro black wire to the frame/chassis for the ground/earth.
1) Cut the BL/R (blue/red) wire between the brake light switch and the brake/tail light cluster.
2) Connect the red wire from the brake light pro to the cut BL/R (blue/red) wire coming from the brake light switch.
3) Connect the green wire from the brake light pro to the cut BL/R (blue/red) wire going to the brake/tail light cluster.
No need to cut any other wires, connect the black wire from the brake light pro to wherever is most convenient on the frame/chassis for the ground/earth.
The flashing brake light I fitted to my blade had a button on the back so when you pressed it, it toggled between 1 flash, 3 flashes and no flashes, I had it set to 3 and planned to put it to 0 when the mot was due, unfortunately some little budding footballer stole it before the mot was due
Marmablade
The Brake Light Pro also has various modes ..... you can test them out here:
