brake light hell!!!!!
guys…ive got issues…we all know this…but this is a bike problem this time…;).
right…
problem : rear light flickers on and off.
Rear brake light comes on when pedal is depresed but when all the way down turns off again…
front brake light flickers for a slpit second and thats it… giving the person behind me no indication that im slowing or stopping…
leckie problem it is for sure…but wondering if its at the arse end of the bike or somewere else…?..
havent got the tools for electrics…so if anyones good at this…please gis a shout…
ta…
smiled:D.
maybe ya got water or gunk in the electrical connectors or wiring loom?? i had similiar problem with my horn, gave it a good clean and its fine :smiley:
brake light switch…contacts worn
change switch and all will be ok…
http://cgi.ebay.co.uk/SUZUKI-GSXR-600-K6-2006-REAR-BRAKE-LIGHT-SWITCH_W0QQitemZ390057046926QQcmdZViewItemQQimsxZ20090604?IMSfp=TL090604157004r18537
£7.00 quid
start at the very begining, it’s a very good place to start
check the bulb, then start at one end and work to the other, so Switchgear then switches to fusebox, fuses, then fuse box to rear light assembly.
do your indicators work ok? numberplate light? no problems with the starter button
Sounds like a dodgy bulb or a bulb on the way out . . . but don’t you have LED brake lights ? In that case unplug and replug all the connectors.
What else does the fuse supply as well as the brake light ? Are those items OK ?
If front and back brakes do the same then unlikely to be the switches.
Just spray the contacts between pedal/lever with WD40
Works for me :smiley:
its fooked shane sell it…
Its them lights Shane i have the same ones on the hornet and they do exactly the same flicker constantly they have a mind of their own:crazy:
Probably a loose conection Mate, where youv’e dropped and crashed so much ;):slight_smile:
