at what point can I say its too cold to do any work, i’ll work from home?
its just about to hit 20 degrees atm and we have a portable heater on and i have my coat on
The temperature in workrooms should normally be at least 16 degrees Celsius unless much of the work involves severe physical effort in which case the temperature should be at least 13 degrees Celsius. These temperatures may not, however, ensure reasonable comfort, depending on other factors such as air movement and relative humidity.’
http://www.hse.gov.uk/contact/faqs/temperature.htm
Enjoy
My office is freezing too but I don’t have the luxury of a heater
My office turn the heating on at a set time of the year and they do the same with the air con regardless of the temp outside!!
CRAP! 16 degrees is well cold!
But there’s no lower limit for shutting down offices
However it can cause you to become ill which means you can either work from home or cause you to be off sick. Great system again huh?
