My bike has been parked up for the last 11 months due to health and financial issues. It’s just had a respray and I finished putting it all back together this afternoon. Tried to start it and it turns over but doesn’t fire. The battery is fully charged and there is fuel in it.
Now while I’m reasonably comfortable dealing with the bodywork of the bike, when it comes to the mechanical side of it I know basically nothing.
My only idea is the spark plugs, but I don’t have the right tools to have a look.
All the obvious is applied correctly … Kill switch and any cut out switches if any you disconnected in the strip down or got perhaps knocked . How does your fuel smell ? Has it gone stale ? It will have a slightly varnishy smell and wont have the kick of fresh petrol .
You can still use the fuel you drain , once it up and going again . Add in between fill ups ,half once half the next time . Is there no plug spanner in the toolkit ?
Sounds about right… over to the Nums for troubleshooting or call in the homestart
(I never tried dealing with this on a bike, car principles apply)
rusty plugs?
damp in the ht leads?
knackered sparks?
distribute looks ok?
Can always stand back, kick it and shout at it with appropriate threats. Spray WD40 everywhere you can get to that’s vaguely connected to the ignition/spark system? I no know :shrug: sorreee
Fuel can go stale (in 6 months), but it can also evaporate and leave a film in the jets and bowl. Which is why you should drain the tank and carbs before storing.
if it is, don’t panic, it’s a very simple job to remove and clean carbs on most bikes. But you will need special tools to re tune them afterwards, again dead easy job. bad news is it will cost money to clean them (as always money )
You may have sucked some of the fuel varnish into the carb passages when you tried to start it (if the fuel has turned to varnish that is), which will involve a thorough clean of the carbs and all the little passages. Pretty straight forward to do, but time consuming to do right.
If you can get it running at all buy a can of fuel system cleaner and dump it in the tank then “ride it like you stole it”. If you’re lucky it’ll clear any crud out of the carbs. Best bet would be to drop the bowls on the bottom of the carbs and give them a good clean first though.
If you can get the plugs out it’ll help you to diagnose the issue. If they’re wet and smell of fuel then at least you’re getting fuel to the cylinders, in which case your problem is likely to be the ignition. However, if it ran fine before you parked it, it’s likely to be the fuel/carbs.
