Bike engines and parts compatibility HELPPP!!!
I hope some can help, there must be a catalog of some sort…
for example ive got a fazer 600 and i have been told that i can fit the yzf 750 front forks… engine too?
hope ye can help :stuck_out_tongue:
Cheers
well things like forks aslong as the legs are the same thickness then they will fit into the fazer top yokes but the wheel might not fit correctly so if it doesnt youll need the yzf 750 front wheel and break calipers but as with the engine as long as the brackets line up then it will slot right in but if they dont line up you can just make some brackets up to make it fit.
anything will fit if you want it to in the end XD
Tried the Fazer forum? Fazer forum clicky
thanks
