Bench testing a fuel pump?
Can it be tested before fitting it inside the tank?
Its a fuel injected jump for the sv looks abit crusty so would like to test it first.
not knowing the layout of the pump but you maybe able to submerse it ( if that is what required in a tupperware type container of petrol and connect it to the bikes wiring ( possible pulse feed rather than continous power feed ) and that should show if it works
so in essence yes it should be possible
aint it a case of putting wires direct to battery etc?
give it power and should pump etc.
Theres 3 wires on it john.
I plugged it in but no pumped fuel so gotta try again but with it fitted in the tank
