Are Bandit 600 & 1200 Parts Interchangeable
Anyone know if say a Bandit 1200 oil cooler & exhaust will fit on to a 600?
If I was to fit a set of Renthal bars, would everything fit back just how they do on the standard bars?
Would K4 GSXR 600 calipers (front & rear) fit on a 600 Bandit?
Ta
many parts can be inter changed.
but k4 gsxr calipers are radial and would not fit…
you could fit a whole front end though…
I believe the oil cooler on a 12 is bigger than the 6.
The oil cooler and exhaust is a little bigger as they attach to a slightly wider engine.
The renthals will be fine, no changes there.
And as Adz says the radial calipers wont fit without some major bracket re-shaping, and then you’d also need the radial mastercylinder.
Cheers for the replies - I had a front ender on my GSXR and the only things that arent bent is the calipers ha ha.
My dads mate has got some 1200 parts he said I could have but if they wont fit theres no point but its just the pipes that have gone a bit rotten on the cooler & I’ve seen some HEL pipes that I’ll get to replace em :slight_smile:
