THat said, it makes sense. OIl will stop any/all dirt, and anything that flies off will go into the engine and lube/or burn off… only thing is does it promote thicker harder coating on the filter in thelong run, leading to suffocation?
had enough of cleaning filters! The one on my KTM two stroke gets cleaned every 3 hours of use, i have 5 and clean and oil them all at once and used them on rotation.
Slightly off topic, I’ve seen a few track bikes where the inside of the airbox is coated with grease, is this to capture any gravel ingested when crashing in gravel traps?
