a socket adaptor
Hi ppl, urgent help required,does anyone know where I could get a socket adaptor? It says 3/8FX1/4M basically the one I’ve got is broken and I desperately need one…pls pls pls…??:smiley: any ideas, suggestions, advice appreciated thank youuuuuu:D
Is this what you are looking for??
http://www.machines4wood.com/mall/productpage.cfm/scottandsargeant/TBTENM380035/98688
summink like that but it has a full wall, no holes in it. And a small square thingy at the end…dammit I cannot speak English!!!GRRRR!!!:smiley:
Get yourself down the nearest halfords they will have some in stock for sure :slight_smile:
That means I won’t have to buy a whole set just coz of one?:smiley:
check your pm box
Is this closer at all??
http://www.abbeypowertools.co.uk/subprod/socket-joints-and-fittings-0001361.aspx
just go there and the search for it… It was the second from the bottom for me… Price = £1.01 :slight_smile:
yes i’m wanting the small one from that three piece set but without the lil ball at the small square tip
Why don’t you want the "Spring-loaded ball bearing for secure socket holding. "?
Interested in hat myself? Any reason you dont kneed the locking ball?
coz the one that broke did not have the locking ball so I want the same :smiley:
The locking ball makes no difference. If there is a groove for the locking ball to pop into it will. If there aint, it’s just pressed back and stays there.
Not important.
Your choice - but you may lose a few sockets into inpenetrable panels (or engines) without it. Why try to make your kit as cheapo as your old kit?
You need balls with your sockets if you know what I mean… Best thing as they do stop sockets disappearing into the dark recesses of your bike/engine/frame.
