-Donor bike : 749 R’04-RAD 02 montjuich aluminium front bracket modified.-RAD 02 montjuich aluminium rear subframe.-Hand made licence plate support.-Montesa rear light.-749 R original fuel tank.-RAD 02 fiberglass montjuich solo seat.-RAD fiber glass front fairing.-10 cm diameter front light with high/low beam , endurance type.-RAD blinkers.-LIPO Batery.-Repositioned electrical wiring, ECU and regulator.-Ohlins front fork-Ohlins rear schock-Rear brake caliper go down position-SP regulable ergal footrest-Carbon fiber front mudguard-Carbon fiber rear mudguard-Carbon fiber side swingaram protectors-Carbon fiber belt covers-Carbon fiber water pump protectors-Magnesium head covers-EVR CTS antihoping clutch-EVR slave piston-Brembo radial calipers,rotors-Brembo PR 19 radial brake pump-Quick open throttle Acossato-WOLFMAN 2 in 1 exhaust system with SPARK omologated megaphone-Modified air funnels-749 R engine
Really nice - but the light should be built flush into the fairing - spoils it sticking out the front like that.
Like it, but as above the headlight is just wrong
perhaps its supposed to be a quick release option?
