Powered by an all-new, shaft-driven, triple-cylinder engine Triumph claim this new model will raise the bar in adventure-touring performance.
With a prototype machine set to be unveiled in Europe next month, exact details are still a little sketchy but Triumph have indicated a fly-by-wire throttle system will feature on the Tiger Explorer enabling traction control as standard fitment. Switchable ABS and cruise control add to the electronics suite with a wide range of electrical accessories catered for thanks to a 950w generator.
On the chassis side of the equation the Explorer will feature a steel chassis, single-sided swingarm and cast alloy wheels ; 19” at the front and 17” at the rear. It is unclear at the moment if more dirt oriented spoked rims will be available as an option on the Tiger Explorer.
All the electronics are great when you’re on the road but if they malfunction when you’re having a ‘proper’ adventure you’re going to be pretty buggered…
X 2, from the side there are so many sharp angles and crap going on its hard to know where to look. It also now looks like a bmw GS - which is a shame as the old tiger was much more handsome than the BMW
Looks nice … though I’m a bit biased. Be interesting to see the fuel tank range … one of the “pleasures” of the 1200 Adv.
Though I do hope Triumph have fixed the painfully hot radiator fan blasting into the groin and a proper button to turn ABS on/off in emergencies :pinch:
